Date/Time: Tue, 23 Apr 2024 07:34:37 +0000
How to split a TPO into RTH and Globes sessions?
View Count: 3667
[2013-04-26 23:43:48] |
jsoviero - Posts: 84 |
I apologize in advance if this is easy to do but I have not been able to figure out the appropriate settings. I want a single daily 24 hour TPO chart to show a regular trading session profile and then separately show the overnight "Globex" session profile. To further clarify my request, I do not want to use the split/merge function, I am trying to set the TPO chart parameters so that the chart will always build this way. In other words the RTH chart would start building with the "A" 30 minute period at 0930 EST and complete at the end of "P" period and then at 0430 EST the Globex chart would begin building and complete the following morning at the beginning of the RTH session. I would like the volume at price profiles to shadow both sessions. Any help is greatly appreciated, thank you.
Date Time Of Last Edit: 2013-04-28 17:29:56
[2013-04-29 09:32:09] |
You need to set the New Period At Day Session Start When Using Evening Session study Input: http://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#TPOProfileSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
