Date/Time: Fri, 14 Mar 2025 09:38:00 +0000
[Programming Help] - Calling the entry scsf function more frequently
View Count: 426
[2022-06-17 06:46:19] |
ycomp - Posts: 321 |
Is there a way to have ACSIL code run more frequently than when the entry function is called? or a way for the entry function to be called more often? I think it is called on each new tick? so if nothing happens for a while it won't be called, right? also can I put the scsf function in a namespace? I'm just moving my related functions to a namespace to have things a bit cleaner in the code, but I think if I move the scsf function it's not going to be called, right? |
