Date/Time: Fri, 14 Mar 2025 06:57:56 +0000
expiration de contrat
View Count: 396
[2022-06-17 06:01:18] |
User220939 - Posts: 36 |
Bonjour, Sur le dax, je suis passé sur le contrat de septembre. Je n'ai plus les données du contrat précédent et toutes mes lignes se sont effacées. y a t'il une case à cocher pour tout récupérer? Merci |
[2022-06-17 14:42:51] |
John - SC Support - Posts: 38653 |
From Google Translate: On the dax, I switched to the September contract.
I no longer have the data from the previous contract and all my lines have been deleted. is there a checkbox to get everything back? First, in order to see the data from previous contracts in the one chart, you need to use a Continuous Futures Contract Chart. Refer to the information here: Continuous Futures Contract Charts Second, when you rollover a contract, you are given an option to rollover the symbol for the chart drawings. In general, you would want to do this. If you forget to, then you can select Chart >> Update Chart Drawings to Current Symbol. Refer to the following: Chart Menu: Update Chart Drawings to Current Symbol (Chart menu) Or, if you want to keep the drawings associated with the older symbol, but still want them displayed on the chart, then ensure that the option for Chart >> Chart Settings >> Chart Drawings >> Show Chart Drawings for Different Symbols is set to Yes. Refer to the following: Chart Settings: Show Chart Drawings For Different Symbols (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
