Date/Time: Mon, 21 Sep 2026 17:54:31 +0000
Custom Symbol with formula - always shows as FSE
View Count: 1289
| [2022-06-17 01:59:12] |
| ejtrader - Posts: 689 |
SC Team - I am following the custom symbol using the following link and always get "FSE" at teh end of the symbol - which as per the document it's an error. Though the chart continues to work as normal. Custom Calculated Symbols [FSC]: Formula Symbol Calculating. This indicates that the Custom Calculated Symbol is functioning properly and calculations are being performed. [FSE]: Formula Symbol Error. This indicates that there is an error with the Custom Calculated Symbol. It could be that one of the symbols that makes up the Custom Calculated Symbol is out of date and therefore there is no data to match up, or that there is a more serious error that would need to be reported. Can I safely ignore the "FSE" error or do I need to any thing different for the formula? Thanks For example: {AAPL-NQTV}*2 -- This gives an FSE error but works fine {AAPL-NQTV}+{NVDA-NQTV} -- This doesn't give FSE error. <settings> <symbol>{AAPL-NQTV}+{NVDA-NQTV}</symbol> <category>Custom Symbols</category> <value-format-code>2</value-format-code> <uses-formula-operators>true</uses-formula-operators> <is-custom-symbol>true</is-custom-symbol> </settings> <settings> <symbol>{AAPL-NQTV}*2</symbol> <category>Custom Symbols</category> <value-format-code>2</value-format-code> <uses-formula-operators>true</uses-formula-operators> <is-custom-symbol>true</is-custom-symbol> </settings> Date Time Of Last Edit: 2022-06-17 03:59:01
| [2022-06-20 11:40:09] |
| Sierra_Chart Engineering - Posts: 24913 |
You could receive this error, when the market is not open for the symbol.
| [2025-07-20 09:24:44] |
| User35525 - Posts: 194 |
I also had this error, and think it's because the market is closed over the weekend. The documentation could be updated to say FSE can happen when the market is not open for the symbol: |
| [2025-07-20 12:16:48] |
Documentation has been updated regarding this.
