Date/Time: Wed, 16 Sep 2026 04:02:48 +0000
connecting uprofit account
View Count: 1509
| [2022-06-16 21:08:03] |
| User538826 - Posts: 11 |
i have followed the step to connect the uprofit evaluation account using rtrader. i have disconnected added rhithmic service dtc, pressed ok, added my credentials etc. it connects up however in the message log it says (attached word document including screenshots). i was previously on the apex funding that worked fine however after adding my credential for uprofit and signing in it still comes up with apex and not an option for the uptrader (please find attached pic in the document as well as credentials.
Private File |
| [2022-06-16 21:42:18] |
| John - SC Support - Posts: 47903 |
The server you are connecting to is a standard Rithmic paper server. We would expect that you should be connecting to a server that starts with UProfitTrader. Check with UProfit to check for sure what server you should be connecting to, and then see if you get your new Account showing in the list of Trade Accounts on the Trade Window: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-20 11:11:51
| [2022-06-17 09:37:59] |
| Ticks - Posts: 212 |
There is no Rithmic server that starts with UProfitTrader @User538826 I experienced the same issue. First, log into the Uprofit website and make sure your eval account is active. Then,make sure that you first log into RTrader with your UProfit credentials and sign the required options that pop up. When you have successfully done that. Start SC. Select the Rithmic paper server-chicago Area-aggregated Place your UProfit credentials (trading username and trading password)into SC If you will be using the free data from Rithmic. Place your UProfit credentials into the market data section also. Click Apply All, then click OK. You should be now able to connect to UProfit for sending orders and the free Rithmic data. Open a Trading DOM and you should see your UProfit account listed. If you have several accounts, they should be listed in the account dropdown list. |
