Date/Time: Fri, 14 Mar 2025 07:07:17 +0000
templates for orderflow
View Count: 4333
[2022-06-16 16:45:58] |
User668378 - Posts: 2 |
For a few days I'm trying to find out if there are any templates that you created or recommend for orderflow trading. Other platforms for example here https://atas.net/chart-templates-2/ give the templates. Please let me know. |
[2022-06-16 18:06:48] |
John - SC Support - Posts: 38653 |
There is a Chartbook for the Numbers Bars at the following link: https://www.sierrachart.com/AdditionalFiles/NumbersBarsExampleChartbook.cht And you will find other files of either chartbooks or study collections for various setups at the following link: Additional Files (Study Collections, Spreadsheets, Chartbooks) But, given the enormous amount of options available, we do not have anything specific for any specific setup. We recommend searching the Internet to see if you can find someone that has something close to what you want then asking if you can get a copy from them (or they may already have it posted). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
