Date/Time: Tue, 26 Nov 2024 11:23:39 +0000
[User Discussion] - pivot study question...
View Count: 1058
[2014-05-03 18:46:46] |
User53765 - Posts: 66 |
Hi Sierra Support, I could not find this information in the table of contents but wanted to ask for the camarilla pivot study under number 5 in the table of contents under pivot study daily what is the calculation for only the 5th support and resistance pivots that is being used as its not noted in the table of contents. Thanks in advance. |
[2014-05-08 04:39:31] |
Will make sure the documentation is up-to-date. Allow two days.
