Date/Time: Fri, 14 Mar 2025 07:13:47 +0000
Current Price Line
View Count: 465
[2022-06-16 15:20:10]
User299107 - Posts: 60
Hi guys,
On my Daily Chart, I have the Current Price Line Indicator set to Last and it works as expected. However, when I set the Input to High, it remains tracking the Last price. I would like one line draw across the chart which indicates the High (of the only Today).
Thoughts?
Eliza
[2022-06-16 17:50:58]
John - SC Support - Posts: 38653
Refer to the information for the Daily OHLC study. If you just want the High, you can turn off the other subgraphs:
Daily OHLC
[2022-06-17 12:17:38]
Mmmmm there are no other subgraphs in this indicator
[2022-06-17 13:02:29]
I'm not talking about the Daily HLOC indicator.... I'm talking about the Current Price Line Indicator
[2022-06-17 15:12:32]
For what you want to do you should use the Daily OHLC study and if you do not want the OLC lines, then you can turn them off.
