Date/Time: Thu, 13 Mar 2025 15:17:48 +0000
Order Allocation to trade accounts brackets size not updating
View Count: 484
[2022-06-16 14:38:35] |
User834699 - Posts: 4 |
Hi I have this scenario: Sim1, Sim2, Sim3, Sim4 accounts added to Order Allocation I start a bracket entry of say 2 lots on Sim1 and it is replicated to the other accounts. I add to this position another 2 lots, and my bracket get updated to 4 lots. But on the other 3 accounts even though the position is now 4, the brackets continue to be 2, the initial value. This way, If I get stopped or hits take profit on sim 1 the position is closed, but on other 3 accounts it closes only 2 lots according to bracket size on those accounts, generating a difference between the account I trade and other 3 replicated trades. Is this a bug? Please advise. |
[2022-06-16 14:41:50] |
We will check on this. We will not be able to get to this until next week though.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-16 14:42:04
[2022-06-19 10:42:51] |
We have identified the problem. This will be fixed in version 2403 which will put out now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
