Date/Time: Thu, 13 Mar 2025 15:34:56 +0000
DOM Settings to display % fill in BIDS and OFFERS coloumn
View Count: 541
[2022-06-16 13:47:08] |
meghnesh - Posts: 17 |
Hi, I have updated my Sierra platform after which the % fill bar has moved to SOLD and BOT coloumns. How can I change it so that the % fill bar is displayed in the BID and OFFER coloumns ? Please refer to the attached image for further details. |
[2022-06-16 17:14:47] |
John - SC Support - Posts: 38635 |
There was a change to how the volume profiles are added for a column, and in that process the default was changed, so that is why it is not showing up the way it used to. You will have to manually change these. Go to Trade >> Customize Chart/Trade DOM Columns and on the right side under the Alignment is the pulldown with the options for Show Volume Bars.
[2022-06-17 15:20:51] |
Thats fixed...thanks a lot...Happy to close this ticket.
