Date/Time: Tue, 26 Nov 2024 11:22:04 +0000
Drawing Horizontal Lines
View Count: 1116
[2014-05-03 18:42:39] |
apollofl - Posts: 95 |
Is it Possible to Draw horizontal lines on the DOM base on a Study? If so How? Or should I say that i would like to place the Bar Difference on the DOM when it reaches a certain Number of Ticks Thanks Date Time Of Last Edit: 2014-05-03 19:05:38
[2014-05-05 04:25:13] |
You can create your own custom study which can be added to a Trade DOM. For the built-in studies, only the ones you see listed in Chart >> Studies can be added.
[2014-05-05 07:30:09] |
Thank you.
