Date/Time: Fri, 14 Mar 2025 07:09:15 +0000
How to set more than 30days of chart data to load as a standard setting
View Count: 525
[2022-06-16 11:19:17] |
Jochen Penther - Posts: 7 |
Hi, under "chart settings" and "data limitung" the standard setting is to load 30 days of data when opening a chart. This is much to less for me, so i searched everywhere how to to set it to 100 or 200 days. I do not want 9000 days or so, but to change the setting for each chart manual is very time expensive. Perhaps i did not find the right setting, so i ask you to give me a hint. Thanks for help! |
[2022-06-16 15:49:14] |
John - SC Support - Posts: 38653 |
Refer to the following: Using Chart Templates: Setting Default Chart Settings For New Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-16 17:07:25] |
Thanks, but there is something missing in description. But i get it. Between step three and four of description you must point with the mouseclick anywhere else in the window. If you do not ... nothing is saved. Perhaps it would be better to program it like your written description. |
[2022-06-16 18:30:25] |
Interesting. We will have to look into this. It should work as written, as long as the option to save is set to "Yes".
[2022-06-16 18:33:35] |
We just went through this and it is working as we expected. What exactly did you see that did not work as stated?
