Date/Time: Fri, 14 Mar 2025 06:54:37 +0000
Targets on order window
View Count: 461
[2022-06-16 09:18:33] |
User894546 - Posts: 47 |
Hi When I change my pre-determined order type in trade window the targets default to 8 ticks whatever my own targets are set to. How do I change the defaults to my own targets? Thank you |
[2022-06-16 15:47:26] |
John - SC Support - Posts: 38653 |
There are certain default settings that are set for some order types. Refer to the information here: Basic Trading and the Trade Window: Trade Window 'Set' Tab But if you are changing the Order Type to something specific and you want specific targets, then you should setup a Trade Configuration so you can just select the configuration and have the parent and child orders all setup as you want them to be. Refer to the information here: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
