Date/Time: Sun, 16 Mar 2025 00:00:22 +0000
Demo, data
View Count: 489
[2022-06-15 18:18:51] |
User728750 - Posts: 24 |
Hi, i want to come back to sierra charts, and i got 2questions. 1. Could i please have demo account one more time so i can try my strategy, so i would know if i should buy and stay here on sierra. 2. If i would buy package 11, i will have data delayed 10minutes but same data like everybody else right? If i dont connect to any futures broker. |
[2022-06-15 20:07:20] |
John - SC Support - Posts: 38678 |
1. We have reset your trial time. 2. You would want to be on Package 5 in order to have access to the Delayed Streaming data for the CME Group, EUREX, CFE, and NASDAQ TotalView. The data is the same as the real-time data, just delayed by 10-15 minutes (depending on exchange). You do not need to be on Package 11 unless you are going to be making a connection to a trading account or other data provider. Refer to the information for the delayed streaming data here: Delayed Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-02 19:44:42] |
Robson - Posts: 76 |
Hi, Can I aslo check demo account? Also need to check if my hardware works fine with SC now or do I need to make upgrade, also would like to check some new SC features, Best Regards Rob |
[2022-08-02 21:23:31] |
Robson: We have activated the trial for your account since you last used the system more than one year ago. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
