Date/Time: Thu, 13 Mar 2025 14:06:26 +0000
Sierra Chart Does not Open
View Count: 389
[2022-06-15 13:44:11]
L2Ltrades - Posts: 61
When I start up Sierra Chart, the initial window describing what to do if connection issues persists open up and after that the actual software does not kick in. Please assist.
[2022-06-15 13:52:25]
So it sounds like there is a problem connecting to whatever service you are using.
Connect to the data feed:
Select "File >> Disconnect"
Select "File >> Connect to Data Feed"
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2022-06-15 13:52:49
