Date/Time: Thu, 13 Mar 2025 13:53:53 +0000
Amp CQG order only - no live data
View Count: 847
[2022-06-15 13:11:18]
User559224 - Posts: 22
I am connected to CQG for order only with Amp, but the SC denali feed doesn't seem to be working, I'm not receiving any data even though I kept the SC symbol translation. The use of SC data services is marked yes, I've toggled it on/of, restarted SC a few times same issue. It works perfectly fine if I connect to SC data, but then I don't have CQG for order routing.
[2022-06-15 13:25:52]
Activate the exchanges that require here:
[2022-06-15 13:27:57]
ah yeah duh i should know this by now thank you.
[2022-06-15 13:37:58]
how soon does this take? it's always been quick in the past. still waiting for data for MNQU22-CME.
[2022-06-15 13:53:55]
It is right away.
You may need to restart Sierra Chart.
Make sure you are using the correct symbols by translating them to the current service. Refer to this command:
Edit Menu: Edit >> Translate Symbols To Current Service
Date Time Of Last Edit: 2022-06-15 13:54:08
