Date/Time: Thu, 13 Mar 2025 13:57:11 +0000
Denali/Teton Brokers With Lowest Day Margins
View Count: 1372
[2022-06-15 12:13:19] |
cstandfast - Posts: 13 |
Hi Everyone I'm in the UK and I am looking for decent low day-margin brokers that use denali/teton infrastructure stack. I have contacted the usual suspects like AMP Futures in US and Cyprus and they say cant support clients in the UK. Cannon Trading also look interesting, but they are TransAct based and from what I can tell, dont yet support Denali/Teton. To save time trawling thru the website lists of supported brokers, is there a thread I can be pointed to or can people recommend brokers to look at? I am looking to trade GC gold contracts as well as NQ, ES etc. Regards -- Colin |
[2022-06-15 12:40:51] |
Cannon Trading also look interesting, but they are TransAct based and from what I can tell, dont yet support Denali/Teton. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-15 12:54:28] |
Stage 5 Trading - Posts: 155 |
Hi @cstandfast, I think you are going to be happy with your decision to move to Teton Order Routing. Stage 5 Trading is a Brokerage firm that has worked hand in hand with Sierra Chart with the implementation of Teton Order Routing. Stage 5 takes great pride in helping traders transition their accounts to Teton Order Routing as seamlessly as possible. Personally, I believe the best solution would be to switch to Sierra Teton Order Routing with Denali for real time and historical data. This is all maintained by Sierra directly, which I feel provides great benefits to traders as Sierra can focus on enhancements instead of maintenance of other third party order routing feeds. In addition, I feel it is the best overall quality and value for traders. You can open an account for as little as $100 and you will receive $0.20 per side commissions on the micros and $0.45 commissions on non micros plus exchange and regulatory fees. Please feel free to contact us and we will gladly assist you with any questions you may have and/or the process of transitioning your account and hopefully helping you improve your current trading solution. We would be able to provide some DOM chartbook layouts that will hopefully be more in line with what you are accustomed to. In addition, we would be more than happy to have a remote session to help get you setup with the new layouts. If you have questions or would like to speak to an assigned personal broker for details, please call us at 1-312-896-9897 or 1-800-258-6675. You can email us at sierrachart@s5trading.com and can also contact us here: https://stage5trading.com/contact/ If you are ready to move to the Teton Order Routing solution right away, we invite you to complete an application by clicking the blue button at the top of the https://stage5trading.com/ page that says Introducing Sierra Chart Teton Order Routing - Click Here to Open an account Thank you, Anthony Giacomin Stage 5 Trading Trading derivatives carries a high degree of risk, and may not be suitable for all investors. Past performance is not necessarily indicative of future results. |
[2022-06-15 13:08:16] |
Both of the things you say about Cannon Trading are not true. They work with multiple clearing firms and they do support Teton order routing. Many thanks SC Support, I have found their Teton web page eventually. Kind Regards -- Colin |
[2022-06-15 14:54:05] |
Got a reply back from Cannon Trading: 1. They support all the technical platform requirements I was after. 2. Offer very good intraday-margins. Does anyone have any concerns with Cannon? Cheers -- Colin |
