Date/Time: Fri, 14 Mar 2025 04:09:47 +0000
Incomplete Denali Data Feed for Crude Oil
View Count: 547
[2022-06-15 10:43:09] |
mosesruppert - Posts: 11 |
The Symbol CLN22 gives only a fraction of the data of the day. Screenshot: https://prnt.sc/H4YwIlq9Q4hf I know from CME that there was more volume traded today than these few contacts. All other contracts (e.g. ES )are displayed correctly. What can I do to get proper data for CLN22? |
[2022-06-15 10:46:49] |
Only provide a chart image by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Most likely the issue you are experiencing is explained here: Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.7 - Comparing Daily Volume to Intraday Chart Bar Volume To make sure there is no missing data in the chart: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-15 10:47:08
[2022-06-15 12:17:49] |
it worked, thank you!
