Date/Time: Sat, 15 Mar 2025 02:42:09 +0000
Incompatible Chartbooks and Sierra Support required to convert them so i can see my charts
View Count: 817
[2022-06-14 20:33:18] |
Baze - Posts: 3 |
The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\Users\donvi\OneDrive\Desktop\SierraChart\SierraChart2401\Data\Chartbook-NOFT-ES-v2.cht | 2022-06-14 20:28:40.188 * Someone please help me with this issue it's been a while since i've been back to using Sierra and now with the most updated and Previous version i get this message when opening my chartbook. thanks |
[2022-06-14 20:57:55] |
Attach the Chartbooks you are having difficulty with and then we will get them converted for you. Instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-15 00:44:56] |
Baze - Posts: 3 |
I've uploaded the files that I purchased 3 years ago from another service. I want to make sure that all these files are compatible with your new SC version. Thank you Date Time Of Last Edit: 2022-06-15 00:52:58
Private File ![]() Private File |
[2022-06-15 17:49:31] |
John - SC Support - Posts: 38678 |
Here are the updated files. Note that there is nothing we can do with the FootprintPatters.dll file. If you have the source code, then you will need to update and recompile it. Otherwise, if you can find the person that developed it for you, have them update and recompile for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-20 17:33:07] |
Baze - Posts: 3 |
Thank you guys, I have two DOM files that need to be converted as well. Please and thank you again.
[2022-06-20 18:06:05] |
Here are the updated versions.
[2022-07-10 16:39:26] |
User955853 - Posts: 2 |
Hello I am trying to use these cht files but sierrachart says incompatible
[2022-07-11 16:24:35] |
Attached are the updated chartbooks.
