Date/Time: Thu, 13 Mar 2025 15:03:27 +0000
Volume by Price Study
View Count: 406
[2022-06-14 17:12:47] |
User39772 - Posts: 311 |
In draw mode: Volume profiles & POC, VAH, VAL, VWAP Lines the function Extended POC until future intersection works. In draw mode: POC, VAH, VAL, VWAP Lines the function Extended POC until future intersection does not work. Why is that the case and is it possible to make this work in the case of the last setting also ? Date Time Of Last Edit: 2022-06-14 17:13:48
[2022-06-14 17:52:45] |
John - SC Support - Posts: 38631 |
This is the case because none of the options for extending any of the lines apply when the draw mode is POC, VAH, VAL, VWAP Lines. We have set this as a Feature Request. But we can not say when we will be able to get to changing this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
