Date/Time: Fri, 14 Mar 2025 09:34:31 +0000
DOM Current Traded Total Volume does not display Volume Bars in version 2400
View Count: 827
[2022-06-14 08:47:21]
User282741 - Posts: 36
I updated to 2400 from 2394 and Show Volume Bars setting is no longer available in Current Traded Total Volume Column from Customize Trade DOM Colums dialog box. My DOMs no longer show volume bars.
Please fix this. See the attached picture how this looks in version 2394.
imagevolumes.png / V - Attached On 2022-06-14 08:44:58 UTC - Size: 23.32 KB - 213 views
[2022-06-14 14:33:34]
John - SC Support - Posts: 38653
In 2400 the "Show Volume Bars" is now a pulldown option that allows you to set the side for the bars. The option is right under the "Alignment" option.
[2022-06-15 09:35:27]
ticinotrader - Posts: 407
Dear John,
Can you please adjust this new feature in the next releases to use the 'Auto' state by default, instead of the 'Off' state?
This new setting and the default 'Off' state 'breaks' the look and feel of every single DOM chartbooks created in the past. Updating the settings on a single DOM is very quick, but in my case, I have to manually update more than 200 chartbooks and ~5-600 individual chart DOMs and standalone DOMs.
Having the Auto function set as default, would eliminate the need to manually update every single chart I ever created.
Thank you in advance for considering this request.
[2022-06-15 09:48:48]
Yes, we will set the default to automatic. It should have been.
