Date/Time: Mon, 17 Mar 2025 18:20:09 +0000
how to trade multiple accounts in 1 rithmic ID all at once?
View Count: 1716
[2022-06-13 21:13:15] |
User576648 - Posts: 26 |
how to trade multiple accounts in 1 rithmic ID all at once? In which I got 3 accounts with the same rithmic ID. I want to execute on all at once and manage them all as well? is that something possible with sierra chart?
[2022-06-13 21:34:22] |
John - SC Support - Posts: 38711 |
Refer to the following: Order Allocation to Trade Accounts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-13 15:17:04] |
william bolger - Posts: 29 |
@john I followed that link and set it up. It says to test it in sim first. How can I test in sim to see if it trades all accounts when it all turns to sim? Do I need to have a seperate trade window open with that account up? Or, will it work if I just use 1 trade window and swap between accounts? |
[2022-09-14 16:28:57] |
Sierra_Chart Engineering - Posts: 18809 |
You just need to enable Trade Simulation Mode: Trade Simulation And to verify positions and orders in other accounts, the easiest thing to do would be just to switch between the other accounts from the Trade Window: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
