Date/Time: Fri, 14 Mar 2025 06:54:36 +0000
ES Rollover (Volume Based)
View Count: 786
[2022-06-13 19:53:49] |
dvant krypto - Posts: 43 |
Hi, I use the Continuous Contract setting: Volume Based Rollover. On the open of the Sunday night session I clicked the automated message to rollover from M22 to U22. I understood, based on the Volume Based Rollover setting that a chart would show a trading day (whether daily, 30m, etc.) based on which contract, M22 or U22, had the most volume. That is to say, the chart would continue to "show" M22 volume until U22 volume exceded it. This does not seem to be the case as my chart is showing U22 volume for last Thursday and Friday even though the M22 traded more volume. Am I doing something wrong? Date Time Of Last Edit: 2022-06-13 19:56:02
[2022-06-19 11:06:57] |
Sierra_Chart Engineering - Posts: 18778 |
If the symbol of the chart is set to the September contract then you will see for at least the current day the September contract. It will not be June. We recommend re-downloading the daily data only for the last two contract months: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
