Date/Time: Thu, 13 Mar 2025 10:18:17 +0000
Trading
View Count: 420
[2022-06-13 16:47:09] |
User925964 - Posts: 1 |
Hello, can you help me with setting live trading. I have account via AMP trading. Is it acceptable or I have to create a new account for SC?
[2022-06-13 17:11:10] |
John - SC Support - Posts: 38621 |
AMP is fine. You should be setup with CQG for your order routing. If this is the case, then follow these instructions to connect your Sierra Chart to your CQG account: CQG Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
