Date/Time: Thu, 13 Mar 2025 10:46:03 +0000
Volume Symbol Rollover Issue
View Count: 655
[2022-06-13 16:44:28] |
Jaydtrade - Posts: 88 |
I keep getting a message on my screen that says "(Volume) Symbol needs Rollover. Click to rollover." I am on the current ES Symbol ESM22 but I just click on it and do the rollover anyway but the error doesnt go away. What is the issue?
[2022-06-13 17:09:41] |
John - SC Support - Posts: 38621 |
Make sure when you do the rollover, that you actually select the next contract in the list for the New Symbol. By default, it shows the same contract as the current one, so if you are not specifically selecting it, then you are not changing the symbol.
