Date/Time: Thu, 13 Mar 2025 10:32:01 +0000
Cannot find my custom study
View Count: 477
[2022-06-13 13:46:33]
JustinQuant - Posts: 5
I built my own custom study,but not like the former ones,I can not find my new costom study through "add custom study"
Here is the message log and the screenshot.
See attached.
DTC Client socket (6) | Closed. | 2022-06-13 13:28:01.052
Found DLL: hedge_signal88_64.dll | 2022-06-13 13:28:17.854
Found DLL: proton_imbl_zone_64.dll | 2022-06-13 13:28:17.854
Found DLL: UserContributedStudies_64.dll | 2022-06-13 13:28:17.854
hedge_signal88_64.dll loading error. Windows error code 126: 找不到指定的模块。 | 2022-06-13 13:28:17.859
VersionNumber is 0 for hedge_signal88_64.dll | 2022-06-13 13:28:17.859
InternalVersionNumberToFileNameMap is empty for hedge_signal88 | 2022-06-13 13:28:17.859 *
Closest match search for: D:\SierraChart2400\Data\hedge_signal88.dll returned empty result. | 2022-06-13 13:28:17.859 *
Found DLL: hedge_signal88_64.dll | 2022-06-13 13:31:05.601
Found DLL: proton_imbl_zone_64.dll | 2022-06-13 13:31:05.601
Found DLL: UserContributedStudies_64.dll | 2022-06-13 13:31:05.601
hedge_signal88_64.dll loading error. Windows error code 126: 找不到指定的模块。 | 2022-06-13 13:31:05.606
VersionNumber is 0 for hedge_signal88_64.dll | 2022-06-13 13:31:05.606
InternalVersionNumberToFileNameMap is empty for hedge_signal88 | 2022-06-13 13:31:05.606 *
Closest match search for: D:\SierraChart2400\Data\hedge_signal88.dll returned empty result. | 2022-06-13 13:31:05.606 *
Pls solve problem asap
Date Time Of Last Edit: 2022-06-13 13:59:42
Private File
[2022-06-13 16:10:38]
John - SC Support - Posts: 38621
There is a problem with your DLL:
You will need to find out why you are getting this error and correct your code and recompile.
