Date/Time: Tue, 22 Sep 2026 07:10:07 +0000
Level 2 data Stocks
View Count: 2349
| [2022-06-13 10:19:00] |
| Torsten Grüß - Posts: 45 |
a nice good day, I have since long my account times again activated (on 11.06.2022) to see now how it goes with the level 2 data for shares. But unfortunately I see now no level 2 data, I have what wrong booked ? Sorry everything is a little different than 12 months ago. I don't think I get Reltime data for Stocks either. Can you please change my Koto so that I get Reltime data in Level 2! Can you please tell me what this will cost me per month so that I can put the money in the SC account for future months? Thanks a lot |
| [2022-06-13 11:15:32] |
Follow the instructions here to use the Delayed Exchange Data Feed: Delayed Exchange Data Feed You can start by getting delayed NASDAQ TotalView data which includes market depth data. The symbol format is documented here: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes For real-time data, follow through the instructions here: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* Let us know if you need further help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-13 11:15:55
| [2022-06-13 11:40:05] |
Can you help me I get the message that I only have a test version and therefore can not Aktiviren data. I have a fully paid version and I have enough money in the account Failed to activate the 'NASDAQ US stock data' exchange. The selected Exchange can only be activated if you have a non-trial Sierra Chart account. For instructions to have a paid account, refer to Renewing Access - By pressing this button, you will be returned to the Exchange Data Feed Features page. |
| [2022-06-13 11:57:07] |
At this time you do have the NASDAQ TotalView exchange active. So you are all set. You will be able to receive the real time NASDAQ TotalView data. Start by using this symbol: AAPL-NQTV Let us know if you need further help or have any issues. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-13 11:57:35
| [2022-06-16 12:39:45] |
I use the tool Price Squawk, this tool unfortunately can not receive the symbol format AAPL-NQTV only the old format AAPL. Is it possible that I can access the old data format with my data contract? |
| [2022-06-16 16:01:31] |
| John - SC Support - Posts: 47955 |
Our older data feed for stocks is still available, just keep in mind that it does NOT have the Market Depth data. Using the older data feed will allow you to enter the stock symbol as just the symbol itself without the additional suffix. If you would want this data, then it is available through our Sierra Chart Exchange Data Feed. The Data Feed itself costs $25.00 for 250 concurrent symbols per month (tracking of 250 symbols at the same time), and the U.S. Equities exchange costs $10.50 per month. You will find the information for this on the following page, including Setup Instructions: Sierra Chart Exchange Data Feed If you then want to discontinue the NASDAQ TotalView data, then you will want to deactivate that exchange at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeedNASDAQ For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-03-29 17:41:28] |
| User149065 - Posts: 14 |
I am recently back using SC Service pack 11, how do I get Level 2 data to work for testing? When I go look it says the package is free. But then somewhere it says my license is expired and wants to charge me $17 USD. I dont mind paying for it but when does it say its included? Also can you direct me to where there are specifics on setting it up and getting it to work in Replay? Thank you |
| [2026-03-29 21:41:42] |
| Sierra_Chart Engineering - Posts: 24928 |
Do you want market depth data for US equities? So you just require historical data? We should be able to give that to you without an exchange fee, but it is one day delayed. Here are the instructions to access the data: Market Depth Historical Graph: Downloading Of Historical Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-03-30 14:26:40] |
Keep in mind that for U.S. Equities the Market Depth data is only available from our NASDAQ TotalView exchange, so you will have to open a symbol using the -NQTV suffix (such as IBM-NQTV). Refer to the following for information on the NASDAQ TotalView exchange: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
