Date/Time: Tue, 04 Nov 2025 19:21:24 +0000
Thread is locked
View Count: 1501
[2022-07-20 20:31:58]
John - SC Support - Posts: 42768
Then we need to first concentrate on the Main Instance, so do not do any work in a Sub-Instance, which is what the changes you have been making have been related to.
Are both of these installations on the same computer? If so, then you can get the Denali data into both of them. If you are not getting any data into the second installation, then make sure the option for Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds is set to Yes. If it is not, then change it to Yes and select OK to close that window. Then select File >> Disconnect followed by File >> Connect to Data Feed.
[2022-07-20 21:57:42]
User994495 - Posts: 47
Both installations are in the same computer and I checked it is already set to Yes.
[2022-07-20 22:26:18]
Then exactly what is the problem you are having on that second installation? There is nothing in your setup that should cause any issues.
[2022-07-20 22:29:39]
I just see Reconnect Wait and when I go connect to data feed in file and click on it nothing happens.
[2022-07-20 22:36:38]
Please copy and paste your Message Log from that second installation to this thread. It sounds like you may have changed the connections to the data server by accident. Refer to the following instructions:
[2022-07-20 22:46:40]
Reading Internal Order ID file. | 2022-07-20 17:41:20.058
Reading Trade Orders file. | 2022-07-20 17:41:20.097
Reading Trade Positions file. | 2022-07-20 17:41:20.097
Reading Trade Account Data files. | 2022-07-20 17:41:20.097
Software version: 2416 64-bit | 2022-07-20 17:41:20.109
Primary Thread ID: 12296 | 2022-07-20 17:41:20.109
Usage end date: 2022-08-11 | 2022-07-20 17:41:20.109
Enabled for: Sierra Chart Historical Data Service. | 2022-07-20 17:41:20.109
Enabled for: Denali Real-Time Exchange Data Feed. | 2022-07-20 17:41:20.109
Enabled for: Delayed Denali Exchange Data Feed. | 2022-07-20 17:41:20.109
Enabled for exchange2: CME | 2022-07-20 17:41:20.109
Enabled for exchange2: EUREX EOBI | 2022-07-20 17:41:20.109
Enabled for exchange2: fairx_exchange.data | 2022-07-20 17:41:20.109
Allow Support for Sierra Chart Data Feeds is enabled. | 2022-07-20 17:41:20.109
Current selected Data/Trading service: DTC - Sub Instance | 2022-07-20 17:41:20.109
Custom symbol settings values: enabled | 2022-07-20 17:41:20.109
Chart Update Interval: 500 | 2022-07-20 17:41:20.109
Intraday Data Storage Time Unit: 1 | 2022-07-20 17:41:20.109
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2022-07-20 17:41:20.109
2022-07-20 22:41:20 Local computer time in UTC | 2022-07-20 17:41:20.109
2022-07-20 17:41:20 Local computer time in SC Time Zone | 2022-07-20 17:41:20.109
2022-07-20 22:41:20 Server time in UTC | 2022-07-20 17:41:20.109
Local computer UTC time and Server UTC time difference: 1 seconds. | 2022-07-20 17:41:20.109
Program path: C:\SierraChart2\ | 2022-07-20 17:41:20.109
Data Files path: C:\SierraChart2\Data\ | 2022-07-20 17:41:20.109
OS Version Number: 10.0 | 2022-07-20 17:41:20.110
Locale Setting: C | 2022-07-20 17:41:20.110
DLLs: UserContributedStudies_64.dll | 2022-07-20 17:41:20.110
Allowed protected custom studies: | 2022-07-20 17:41:20.110
Crash reporter started: true | 2022-07-20 17:41:20.110
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-07-20 17:41:20.136
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-07-20 17:41:20.273
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-07-20 17:41:20.273
Received 5 login tokens. | 2022-07-20 17:41:20.606
Files to Open on Startup | Opening file: ExampleChartbook.cht | 2022-07-20 17:41:24.756
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:26.770
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:26.790 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:41:26.790
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:26.790
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:26.790
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:26.807
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:26.808
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:26.808
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:28.803
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:28.804 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:41:28.804
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:28.804
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:28.804
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:28.819
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:28.819
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:28.819
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:30.830
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:30.831 *
DTC Client socket (2) | CloseSocket call. | 2022-07-20 17:41:30.831
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:30.831
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:30.831
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:30.852
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:30.852
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:30.852
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:32.862
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:32.884 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:41:32.884
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:32.884
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:32.884
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:32.905
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:32.905
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:32.905
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:34.905
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:34.905 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:41:34.906
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:34.906
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:34.906
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:34.920
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:34.920
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:34.920
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:36.928
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:36.929 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:41:36.929
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:36.929
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:36.929
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:36.952
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:36.952
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:36.952
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:38.943
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:38.972 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:41:38.972
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:38.972
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:38.972
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:38.991
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:38.991
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:38.991
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:40.989
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:40.990 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:41:40.990
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:40.990
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:40.990
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:41.007
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:41.007
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:41.007
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:43.019
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:43.019 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:41:43.020
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:43.020
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:43.020
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:43.034
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:43.034
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:43.034
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:45.049
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:45.065 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:41:45.065
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:45.065
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:45.065
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:45.085
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:45.085
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:45.085
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:47.083
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:47.084 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:41:47.084
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:47.084
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:47.084
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:47.102
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:47.102
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:47.102
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:49.097
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:49.098 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:41:49.098
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:49.098
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:49.098
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:49.116
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:49.116
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:49.116
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:51.133
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:51.155 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:41:51.155
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:51.155
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:51.155
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:51.166
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:51.166
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:51.166
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:53.167
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:53.168 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:41:53.168
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:53.168
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:53.168
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:53.185
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:53.185
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:53.185
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:55.201
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:55.208 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:41:55.208
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:55.208
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:55.208
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:55.224
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:55.224
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:55.224
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:57.231
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:57.248 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:41:57.248
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:57.248
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:57.248
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:57.259
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:57.259
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:57.259
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:41:59.268
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:41:59.268 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:41:59.269
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:41:59.269
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:59.269
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:41:59.299
DTC - Sub Instance | Disconnected. | 2022-07-20 17:41:59.300
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:41:59.300
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:01.316
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:01.316 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:01.321
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:01.321
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:01.321
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:01.336
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:01.336
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:01.336
Saved Chartbook: ExampleChartbook.cht. Time: 0.0002 seconds. | 2022-07-20 17:42:03.283
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:03.339
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:03.367 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:03.367
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:03.367
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:03.367
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:03.381
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:03.381
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:03.381
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:05.380
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:05.381 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:05.385
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:05.385
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:05.385
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:05.399
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:05.400
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:05.400
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:07.401
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:07.401 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:07.402
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:07.402
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:07.402
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:07.408
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:07.409
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:07.409
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:09.416
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:09.440 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:09.447
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:09.447
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:09.447
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:09.464
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:09.464
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:09.464
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:11.467
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:11.468 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:11.468
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:11.468
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:11.468
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:11.487
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:11.487
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:11.487
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:13.501
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:13.502 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:13.502
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:13.502
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:13.502
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:13.520
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:13.520
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:13.520
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:15.532
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:15.550 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:15.550
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:15.550
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:15.550
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:15.568
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:15.568
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:15.568
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:17.602
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:17.602 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:17.603
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:17.603
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:17.603
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:17.618
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:17.618
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:17.618
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:19.676
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:19.677 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:19.677
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:19.677
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:19.677
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:19.700
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:19.700
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:19.700
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:21.705
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:21.729 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:21.729
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:21.729
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:21.729
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:21.751
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:21.751
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:21.751
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:23.740
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:23.740 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:23.740
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:23.740
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:23.740
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:23.766
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:23.766
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:23.766
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:25.771
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:25.771 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:25.771
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:25.771
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:25.772
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:25.790
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:25.790
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:25.790
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:27.800
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:27.818 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:27.818
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:27.818
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:27.818
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:27.835
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:27.835
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:27.835
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:29.840
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:29.841 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:29.841
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:29.841
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:29.841
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:29.859
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:29.859
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:29.859
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:31.860
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:31.861 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:31.875
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:31.875
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:31.875
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:31.895
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:31.895
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:31.895
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:33.897
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:33.920 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:33.920
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:33.920
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:33.920
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:33.937
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:33.937
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:33.937
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:35.937
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:35.938 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:35.938
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:35.938
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:35.938
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:35.953
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:35.953
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:35.953
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:37.962
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:37.962 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:37.962
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:37.962
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:37.962
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:37.977
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:37.977
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:37.977
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:39.999
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:40.027 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:40.027
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:40.027
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:40.027
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:40.045
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:40.045
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:40.045
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:42.042
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:42.042 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:42.042
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:42.042
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:42.043
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:42.065
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:42.065
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:42.065
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:44.093
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:44.094 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:44.094
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:44.094
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:44.094
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:44.113
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:44.113
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:44.113
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:46.126
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:46.146 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:46.146
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:46.146
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:46.146
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:46.173
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:46.173
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:46.173
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:48.182
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:48.183 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:48.183
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:48.183
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:48.183
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:48.204
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:48.204
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:48.204
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:50.195
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:50.196 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:50.196
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:50.196
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:50.196
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:50.212
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:50.212
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:50.212
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:52.215
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:52.236 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:52.236
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:52.237
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:52.237
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:52.254
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:52.254
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:52.254
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:54.254
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:54.255 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:54.255
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:54.255
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:54.255
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:54.281
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:54.281
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:54.281
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:56.277
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:56.286 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:56.286
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:56.286
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:56.286
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:56.317
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:56.317
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:56.317
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:42:58.319
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:42:58.341 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:42:58.342
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:42:58.342
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:58.342
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:42:58.354
DTC - Sub Instance | Disconnected. | 2022-07-20 17:42:58.354
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:42:58.354
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:43:00.367
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:43:00.367 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:43:00.368
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:43:00.368
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:43:00.368
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:43:00.390
DTC - Sub Instance | Disconnected. | 2022-07-20 17:43:00.391
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:43:00.391
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:43:02.384
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:43:02.400 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:43:02.400
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:43:02.400
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:43:02.400
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:43:02.418
DTC - Sub Instance | Disconnected. | 2022-07-20 17:43:02.419
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:43:02.419
DTC - Sub Instance | Connecting to the server 157.90.1.40.. Port 10150 | 2022-07-20 17:43:04.419
Error getting address info for 157.90.1.40.. Windows error code 11001: No such host is known. | 2022-07-20 17:43:04.419 *
DTC Client socket (1) | CloseSocket call. | 2022-07-20 17:43:04.419
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-07-20 17:43:04.420
Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:43:04.420
DTC Client socket (0) | CloseSocket call. | 2022-07-20 17:43:04.442
DTC - Sub Instance | Disconnected. | 2022-07-20 17:43:04.442
Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-07-20 17:43:04.442
[2022-07-20 23:03:02]
You need to setup this second installation the same as your first installation. In other words, you need to set it up to connect to your CQG account, unless there is some reason you do not want it connected to your CQG account.
Refer to the instructions at the following link to connect that installation to CQG:
CQG Trading Platform Service: Setup Instructions
[2022-07-20 23:27:46]
For the second installation I changed the current selected service from DTC- Sub Instance {Trading} to CQG WebAPI and I get a connection error message. Please see attached.
Thank you for your attention.
attachmentService Connection Error .pdf - Attached On 2022-07-20 23:27:26 UTC - Size: 2.57 MB - 329 views
[2022-07-21 17:08:14]
This is a long thread with a lot of postings. You cannot have two or more connections to CQG. Only one of them.
You can have multiple connections to Teton order routing:
We do recommend using Teton order routing if you are trading the CME Group of markets.
Or you can use a sub instance of Sierra Chart using the New Instance feature:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
Date Time Of Last Edit: 2022-07-21 17:08:59
[2022-07-21 19:12:42]
As noted above, you are best off to use Sub-Instances of one installation rather than trying to get a second Sierra Chart installation to connect to the first.
If you have some reason to continue with 2 different installations and want the second one to connect through the first, then you would need to follow these instructions:
https://www.sierrachart.com/index.php?page=doc/NewInstance.php#InstructionsForSharingDataBetweenSeparateInstalledInstances
Note that the process is somewhat complicated, but it can be done. But it is not something that we can help.
