Date/Time: Wed, 27 Nov 2024 08:52:02 +0000
Transferring Chartbooks and Studies from one Computer to Another
View Count: 578
[2022-06-11 19:37:02]
User663303 - Posts: 1
I installed a new copy of Sierra on a new computer and I copied all my data files (chartbooks, studies, etc) from the previous computer. I can see the names of my chartbooks and studies, however, the Chartbooks do not open and instead show up in the Message Log as "The Chartbook file is not a valid Chartbook File...."
As for my studies: while they appear under my Analysis menu window, when I select a study it does not populate at all even though the study appears with a check mark after I select it as if it were showing as the current study file open.
Please let me know if there is anything I need to do to get my chartbooks and studies opened. Thanks for your attention.
[2022-06-12 08:05:55]
Refer to:
Transferring Sierra Chart Settings and Data From Existing Installation to New Installation
[2023-09-03 00:27:06]
User519569 - Posts: 18
I was having trouble with my computer so I bought a new one and was in the process of transferring everything to the new computer when the old one died.
I assume I'll have to re-create all my chartbooks and settings from recollection, but I thought I'd at least ask if there is a way to get all my chartbooks and settings onto my new computer now that the old one is gone. I bet the answer is that I should have backed everything up, right?
[2023-09-03 19:25:53]
Sierra_Chart Engineering - Posts: 17191
Do you still have the old computer? You should be able to remove the storage drive/device from it and access the files on it.
