Date/Time: Fri, 14 Mar 2025 07:20:07 +0000
How to compare the size of each price level and color it
View Count: 461
[2022-06-10 15:32:30] |
User897008 - Posts: 48 |
How to compare the size of each price level and color it? see attachment. |
[2022-06-10 15:44:36] |
John - SC Support - Posts: 38653 |
Refer to the following Numbers Bars options: Numbers Bars: Numbers Bars Background Coloring Methods Numbers Bars: Numbers Bars Text Coloring Methods For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-10 16:13:56] |
(x) price levels increases or decreases continuously Maybe I need to read your link carefully... |
[2022-06-10 16:26:26] |
What we pointed you to are the coloring options we have available. We do not know what was used in the image you supplied. If you believe that the coloring was done based on a continuous increase/decrease, then that is not something that we have in our Numbers Bars. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
