Date/Time: Thu, 13 Mar 2025 13:51:04 +0000
Create Toolbar with Buttons for Charts
View Count: 618
[2022-06-10 13:35:22] |
User600202 - Posts: 37 |
I have quite a number of charts for each Chart Book I use, i.e. Softs (each product has multiple charts.) I have tabs at the bottom so I can "just" click on them but they are wider than the screen width so I have to use the "arrows" to roll left or right to see which chart tab I need to click on. This makes is slower than I'd like it to be. Is it possible for me to create a custom toolbar which I could perhaps float, and that would have a button for each chart that I could just click on (without having to navigate through the tabs, etc.)? |
[2022-06-10 13:42:31] |
We will look at supporting the Window tab bars to be aligned to the left or right of the main window. That should not be a problem and then once they are in a vertical format like that you will see more tabs especially if you have a high-resolution monitor with a lot of vertical height. You can also select the chart through the CW menu. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-10 13:49:17] |
That would be quite convenient, thanks.You can also select the chart through the CW menu.
I am aware of that but it is not really faster than just scrolling left/right with the tab arrows.
