Date/Time: Fri, 14 Mar 2025 07:18:57 +0000
MY charts on ES and my trading quote are at MES but its not working.
View Count: 562
[2022-06-10 11:39:19] |
User576648 - Posts: 26 |
MY charts on ES and my trading quote are at MES but it's not working. I reset the sierra and everything. I seem to have this bug every rollover period.
[2022-06-10 12:31:39] |
What exactly is not working?
[2022-06-10 13:17:02] |
trading the MES on ES charts
[2022-06-10 13:27:22] |
The settings look correct. Are you getting a rejection message upon order entry? Check the Trade >> Trade Service Log. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-10 13:30:37] |
yes check the image below
Date Time Of Last Edit: 2022-06-10 13:42:56
[2022-06-10 14:40:29] |
John - SC Support - Posts: 38653 |
This has nothing to do with the symbols. The issue is that you have setup a Profit Limit in Global Profit/Loss Management, and you are above that profit limit, therefore all new orders are being immediately flattened. You need to change your settings for Global Profit/Loss Management. Refer to the information here: Global Profit/Loss Management For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
