Date/Time: Fri, 11 Sep 2026 15:14:14 +0000
[User Discussion] - HELP! SPREADSHEET FORMULA FOR SCALING IN ON REVERSALS
View Count: 968
[2022-06-10 09:14:18]
User9890731 - Posts: 47
HI and thanks in advance,
I would like someone to help with a formula that ''scales in'' by 1 contract each time the current open position triggers a reversal order that I already have on cell K3 and M3...
current reversal entry formula ; K3:=ID0.SG4@3>ID3.SG2@3
M3:=ID0.SG4@3<ID3.SG2@3
THANKS
Date Time Of Last Edit: 2022-06-10 09:18:49
[2022-06-10 12:53:06]
Sawtooth - Posts: 4352
Maybe this would work for you:
https://www.sawtoothtrade.com/example-2.html
[2022-06-10 13:55:16]
Thanks Tomgilb,
To be clear on what i actually need the spreadsheet to perform during the trade execution the following conditions must be met;
1) I need the 1st parent order to have a main target of say 100ticks,
2) when a reversal trade is executed, 2 contracts must be traded but the target for the parent position should remain 100tick while the 2nd position and every other subsequent position must have a consistent target say 20ticks every time ''scaling in '' occurs.
so if 4 reversals occur, then out of the 4 open positions, 3 positions should have a target of 20ticks while the parent has a 100tick target.
[2022-06-10 14:52:23]
Try this:
- Use J82/J83 to set an exit quantity for exits at 20 ticks.
- Use L3/N3 to exit all but one lot at 20 ticks.
- For the final 100 tick target exit, use J29.
[2022-06-10 16:18:21]
HI TOM,
Lastly, how could you edit the J26
(=IF(J8<>0,ABS(J8),((J52/H1)-INT(J52/H1))/H2+1)
formula to only add lots/contracts provided non of the targets have been hit before a reversal has occurred.
hence if a target is hit then it resets back to 1 contract.
hence removing the limitation of ''assuming you're all in/out''
[2022-06-10 21:20:27]
how could you edit the J26 formula to only add lots/contracts provided non of the targets have been hit before a reversal has occurred. hence if a target is hit then it resets back to 1 contract.
Since this formula resets to 1 each time J52 increments to again be divisible by H1, I can't think of a way to reset to 1 with another condition in the middle of completing a divisibility by H1.
I'm not saying it's not possible to do what you want, only that it's not something that has an easy answer.
