Date/Time: Mon, 21 Sep 2026 10:22:51 +0000
error saving downloaded files
View Count: 916
[2022-06-10 07:46:42]
User313515 - Posts: 1
I have an error installing the sierra chart.
writes (error saving downloaded files to local system, stopping installation. Check log. Press install to retry.
I tried everything, but failed.
I work on a Mac. I have Paralles installed with windows 10. Trail version.
Can you help me please
Pavel
[2022-06-10 13:51:20]
John - SC Support - Posts: 47939
This usually is related to how the file system is recognized on a Mac, and our installer is only setup to deal with Windows file systems. The only solution is to use our Zip installer instead. Refer to the following:
Software Download: Sierra Chart Zip Installer
