Date/Time: Fri, 14 Mar 2025 04:31:47 +0000
Installing SC on new PC
View Count: 462
[2022-06-09 22:19:18]
58LesPaul - Posts: 429
Installation went well, all the backups went well except Default Study Settings, I can't find which folder they go to? I assume when I copied them they were in a Default Study Settings folder but the new installation doesn't have that folder.
[2022-06-09 22:29:44]
John - SC Support - Posts: 38653
Default Study Settings go into a folder named 'DefaultStudySettings' that is located under the main Sierra Chart Installation folder. Just create the folder and then put any default study settings files you have (the files have a file extension of .defaultsettings) into that folder.
