Date/Time: Thu, 13 Mar 2025 14:30:37 +0000
Issue loading charts with CQG
View Count: 589
[2022-06-09 21:53:18] |
DF86 - Posts: 14 |
Ive had this connection a while and always worked fine, just recently im getting 2 errors wen trying to load charts. " Real time market data only supported with sierra chart data feed for symbol F.US.EPM22." " Download failed Historical data only supported with Sierra Chart Data Feed". Not sure what to do, Ive been switching between a Rithmic and CQG Connection. I can get Rithmic to load ok but not CQG. Is there anything I can do? |
[2022-06-09 22:15:54] |
John - SC Support - Posts: 38625 |
With release 2394, we have stopped allowing data from CQG for the CME Group and EUREX into Sierra Chart. Refer to the following for more information: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2394 You can either downgrade to version 2393, or use our Denali Exchange Data Feed. Refer to the following for how to downgrade your software: Software Download: Software Rollback Procedure And refer to the following, which includes Setup Instructions for the Denali Exchange Data Feed: Denali Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-15 21:30:24] |
$teve.00 - Posts: 20 |
I just signed back up after being off for 2 months. Im having the same issues. I use amp as broker. they don't have Teton yet. I'm paying for package 11. How do i get this to work where i only have 1 instance of SC open and be able to trade and still get denali data?
[2022-06-15 21:40:05] |
You need to reactivate the exchange(s) you want at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
