Date/Time: Fri, 14 Mar 2025 12:16:05 +0000
Tool Configuration vs Tool Selection
View Count: 413
[2022-06-09 20:38:41]
betrading - Posts: 7
Hi I've tried searching but I could not find it.
An option where the Tool Configuration will stay the same regardless of the tool I use.
Right now if I click on a Tool it will revert back to the last Tool Configuration that was used with it.
I am setting up the same color scheme for different tool configurations & it would be nice for that Tool Configuration be the master when switching between tools instead of clicking on a tool & then also having to click on the proper Tool Configuration.
Thank you.
[2022-06-09 22:00:18]
John - SC Support - Posts: 38653
This is not the way it works. As you noted, the system is setup to keep the last tool configuration used as the active tool configuration.
But, refer to the following information for how to setup a Control Bar item that selects the Tool and Tool Configuration at the same time:
Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step
