Date/Time: Tue, 26 Nov 2024 09:40:56 +0000
QuoteBoard Multiple Instances
View Count: 1200
[2014-05-02 11:49:26] |
User22153 - Posts: 46 |
Hello Support, I've tried adding symbols on the Quoteboard from another Instance onto the main trading service. However, I don't know what to symbol formation I need to put in because I have Interactive Brokers as the main trading service on one instance and Sierra Charts FX Data on another. Both services use different symbols for FX, so I was wondering if its possible to add symbols from the SC FX data service on the the Interactive Brokers QuoteBoard? Thanks |
[2014-05-02 17:41:35] |
No. This is not supported.
