Date/Time: Tue, 26 Nov 2024 13:52:08 +0000
Adjust drawn VP
View Count: 1055
[2014-05-02 06:06:44]
AKR - Posts: 523
I dont know if it is up to the new version, but I cannot adjust existing drawn volume profiles anymore.
Furthermore the figures in number bars charts are huge suddenly, though I did not change any graphic setting.
Date Time Of Last Edit: 2014-05-02 06:10:20
[2014-05-02 07:10:50]
Update Sierra Chart again by selecting Help >> Download Prerelease to get the very latest revision. The version number is the same but the problem with adjusting volume profiles is resolved.
Provide more information about Numbers Bars. We need to see an image of the chart and how you know that the values are wrong. Here are the instructions provide a chart image:
https://www.sierrachart.com/index.php?l=PostingInformation.php#Image
[2014-05-02 07:26:34]
AKR - Posts: 523
no I guess the numbers will be right. The font size just changed without me changing anything in the graphic settings.
Can it be due to fact I did cancel EUREX SC feed (because want to subscribe to level I only ).
http://www.sierrachart.com/image.php?l=1399015532985.png
[2014-05-02 07:33:30]
Open the Study Settings window for the Numbers Bars study and set the Font Size input to the font size that you want.
We can see the automatic font size is not working properly. We will fix that.
[2014-05-02 07:36:47]
AKR - Posts: 523
still can not adjust volume profile
[2014-05-03 09:08:57]
Update to the latest version and let us know if this is still a problem.
[2014-05-05 05:48:24]
AKR - Posts: 523
working. thx
[2014-05-16 06:08:14]
AKR - Posts: 523
I did update to new version today and now again I can not adjust drawn VPs.
Well actually this is true only for some VPs. Some I still can adjust. stange.
Date Time Of Last Edit: 2014-05-16 06:09:17
[2014-05-16 06:13:17]
AKR - Posts: 523
hm well. seems it works for new drawn ones. so forget the post.... I can live with that.
[2014-05-16 06:19:44]
Existing drawn volume profiles can have a problem due to some underlying changes we made with chart drawings. It was a scenario we did not consider.
