Date/Time: Thu, 13 Mar 2025 07:55:06 +0000
Range bars
View Count: 480
[2022-06-07 13:18:57] |
User66360 - Posts: 81 |
Did the range bars disappear? I cant find them since the updated format.
[2022-06-07 13:34:49] |
They are still supported. You can configure them through Chart >> Chart Settings >> Bar Period: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TimePeriodPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
