Date/Time: Thu, 13 Mar 2025 07:37:41 +0000
remove order options when right click to open menu window
View Count: 605
[2022-06-07 09:14:59]
User 144164 - Posts: 17
220607-0412 Chicago time
Extensive searching for option to do this including the support board but no results found.
Have executed an order by accident when right clicking to open menu for NON order selection.
Please advise how to remove the left column that has the order options listed to execute or cancel orders.
By default when right clicking to open the menu (for NON order selection) the menu opens with the cursor directly on top of order options.
All orders are executed from the trade window or DOM so there is NEVER a need to execute an order from a window that appears when right clicking in an open area of the chart.
Thank you in advance for your excellent service!
[2022-06-07 14:57:36]
John - SC Support - Posts: 38621
You can remove all the trade related items from the list. Select Global Settings >> Customize Chart Trade Menu to remove them, or change what is listed. Refer to the following:
Global Settings Menu: Customize Chart Trade Menu (Global Settings menu)
