Date/Time: Thu, 13 Mar 2025 07:49:48 +0000
Diagonal Bid/Ask Extreme Marker Threshold - Number Bars Study
View Count: 446
[2022-06-07 02:55:35] |
User277893 - Posts: 5 |
Hi SC, I am using the Number Bars study, and I cannot find the option for the "Diagonal Bid/Ask Extreme Marker Threshold" described here: https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#Input_DiagonalBidAskExtremeMarkerThreshold According to the help guide, it should be between "Enable Diagonal Zero Bid/Ask Compares" and "Highlight Maximum/Minimum Value Based On", but as you can see in the attached screenshot, it is not there. Perhaps there is a new way to achieve the same with a different setting? Please advise when convenient. Thanks. -Rafael |
[2022-06-07 14:48:31] |
John - SC Support - Posts: 38621 |
Our apologies. That should not have been in the documentation and it has been removed. That option is not available.
[2022-06-07 15:12:08] |
Hi John, no worries. I will look for another way to achieve the same result. Thanks for replying.
