Date/Time: Tue, 26 Nov 2024 09:25:13 +0000
Bid volume vs Ask volume study
View Count: 1041
[2014-05-01 19:21:00] |
mayerrs - Posts: 70 |
hi, i would like to set this study more personaly. i would like to set this: when is Bid volume for example twice bigger then ask volume then this study bar is width 2. or diferent color, whatever but i would like to highlight this bar of study. is this somehow possible? thanks |
[2014-05-01 21:12:37] |
This can be done. The source code is provided with Sierra Chart for this study. Refer to this page to make changes to it: https://www.sierrachart.com/index.php?l=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
