Date/Time: Thu, 13 Mar 2025 07:51:18 +0000
Delta %
View Count: 366
[2022-06-06 19:24:26] |
Mr.Lucifer - Posts: 9 |
How do i get delta % on the bottom of my footprint like in photo
Private File |
[2022-06-06 20:59:12] |
John - SC Support - Posts: 38621 |
Those lines are from the Numbers Bars Calculated Values studies (there is a 1 and 2, which just have additional data). Delta % is part of the Numbers Bars Calculated Values 1 study and is the subgraph named Ask Volume Bid Volume Difference Percent. You can change the name of the subgraphs, which is what the person whose Sierra Chart is imaged had done. Refer to the information starting here: Numbers Bars: Displaying Numeric Information Below Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
