Date/Time: Thu, 13 Mar 2025 07:32:12 +0000
Parallel Sounds vs. Serial ?
View Count: 576
[2022-06-06 17:21:00]
User656492 - Posts: 146
I have no idea if this is hard or easy, but audio alerts would be much more helpful if they could be played in parallel vs. waiting for a prior sound to finish before starting the next. Maybe this is a windows limitation with .wav files?
Ex: A New High audio alert played at the same time as a High Volume audio alert played at the same time as a High Volume per Second audio alert is far more interesting to hear at the same time vs. stacked up.
[2022-06-06 17:44:42]
John - SC Support - Posts: 38621
Refer to the following setting:
General Settings Window: Wait for Prior Alert Sound to Finish Before Playing Next Queued Sound (Global Settings >> General Settings >> Alerts >> Additional Settings)
[2022-06-06 17:59:17]
Thanks, John. This is close, but not quite the same as it just has one sound step on the previous. So, one can overwrite the other as opposed to play WITH the other.
I do appreciate the fast response!
