Date/Time: Fri, 11 Sep 2026 07:28:11 +0000
additional account
View Count: 669
| [2022-06-06 16:55:52] |
| User343151 - Posts: 4 |
Hi, i've got an account with Amp that i would like to add to my sierra charts. How can i add this?
| [2022-06-06 17:42:49] |
| John - SC Support - Posts: 47841 |
Is your existing account also with AMP, and is this second account under the same login as your first? If so, then you would have access to both accounts with your current connection. Refer to the following for how to change your Trading Account: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) If, on the other hand, your second account is a separate login, then we recommend installing a second Sierra Chart installation on the same computer and connecting that to your second account. Refer to the following instructions to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart Also, in the first case above, you could also have separate installations for each account if that is easier for you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
