Date/Time: Thu, 13 Mar 2025 07:33:37 +0000
I DONT HAVE REAL DATA
View Count: 426
[2022-06-06 16:54:32] |
caraujo00 - Posts: 2 |
Hi, I update my services to SP11, but still I dont have REAL TIME DATA, SInce a year ago, I used to use CQG WEB API (with my credentials from AMP futures) and I seeing is not working, What I have to do to get REAL TIME DATA ?
[2022-06-06 17:38:46] |
John - SC Support - Posts: 38621 |
If you are wanting data from the CME Group, then you need to activate the appropriate exchange(s) at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
