Date/Time: Sun, 24 Nov 2024 08:53:45 +0000
AMZN showing pre-split price, no data after split
View Count: 784
[2022-06-06 12:49:01] |
frozentundra - Posts: 91 |
Good morning. AMZN had a stock split over the weekend (June 5, 2022). SC is still showing the old price and I can't seem to load any data from this morning's premarket. I tried deleting all the AMZN files in my /data folder and re-downloading, but got the same result. How do I get AMZN to display the most recent data with the stock split reflected? Thank you in advance. |
[2022-06-06 14:57:41] |
User757136 - Posts: 2 |
I am having the same issue. I went to Edit > Delete and Download all Data. It asked for confirmation, deleted and downloaded but then just added the pre-split price. This is happening on some but not at all charts in the chart book. My Daily & Weekly charts are adjusted to the new price but all intraday charts are the old price. Thank you for your help. |
[2022-06-09 17:29:39] |
User39653 - Posts: 11 |
I have the same problem. No intraday data on AMZN since the split on Monday
[2022-06-09 21:22:46] |
The split has been taken care of in our data. If you are not seeing the updated information then select Edit >> Delete All Data and Download to get the updated data. We are not seeing any issues with the Intraday data for AMZN. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-09 21:48:49] |
We have performed this split on our NASDAQ TotalView data as well now. These splits are handled manually. You also have the ability to adjust the data yourself without relying upon us: Adjusting Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-06-09 21:49:12
[2024-06-10 22:27:37] |
jsandlan - Posts: 46 |
I'm seeing this for NVDA today. Is it possible to have this resolved without having to do it manually?
Date Time Of Last Edit: 2024-06-11 22:03:35
