Date/Time: Fri, 14 Mar 2025 04:41:57 +0000
Line styles disappear when Width/Size above 2
View Count: 377
[2022-06-05 19:25:48]
503 - Posts: 10
Vertical lines' Line Style becomes continuous when Width/Size is set above 2, horizontal lines also lose style integrity when width is set higher. Could the line style be scaled in accordance with Width/Size setting?
Also after upgrading to latest version, window Maximize do not work. When maximized it fills 1/4 of the screen and the icon (next to X) does not change, it's still a 'maximize' icon and if clicked again, a window goes back to its previous place.
[2022-06-06 11:00:24]
Refer to all of the documentation related to this here:
Chart Studies: Subgraphs Tab >> Line Style
Chart Studies: Subgraphs Tab >> Draw Style
This absolutely is not an issue with a particular version. Whatever problems you have in this regard must be related to the operating system. Although are you referring to Chart windows or what type of window?
Date Time Of Last Edit: 2022-06-06 11:01:00
