Date/Time: Thu, 13 Mar 2025 07:36:00 +0000
CBOE Indices
View Count: 481
[2022-06-05 14:29:29] |
VolTrader73 - Posts: 136 |
Hello. I wanted the CBOE indices instead of the CFE. Had no issue activating and de-activating the CFE yet trying to activate CBOE, I get the attached screen. I have Daneli with MBO and Teton. Please advise or just activate it for me if its just the 5.25 on top of what I have. |
[2022-06-06 15:23:56] |
John - SC Support - Posts: 38621 |
In order to get the CBOE Indices, you need to go through the Setup Instructions for the Sierra Chart Exchange Data Feed, which has a $25.00 per month connection fee. Refer to the following: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-06 17:29:53] |
this is on top of the Daneli MBO I already have ? Why wouldn't the CFE (CBOE owned) incur that charge ? Please explain |
[2022-06-06 17:46:46] |
The CBOE charges separately for these. So having one does not give access to the other.
